Discuss ADVICE -Shower leaking via 300mm UPV panels gap? Best way to seal?? in the USA area at PlumbersForums.net
Hi All
Noticed the floor around shower had a pool of water, looked like shower leaking from below, presumed it was trap but all good, could not see where water was coming from?
I turned on the showed head and viewed underneath base and the ONLY time i had a leak was when the water jet was hitting on vertical join in the UPVA cladding (middle one in pic).
How can i seal this tiny gap cleanly? I looked into spray sealants, are they thin enough to lightly spray into the tongue/groove join/gap?
Do i just smear silicone along the whole vertical length/tiny gap and make a mess byt trying to force it on the join???
Would superglue work, it's thin and could fill the joint???
Or should i just glue a piece if vertical 'make up' and seal each side??
I also removed the disability seat but that was after i found the where the leak was coming from, all silicone will be removed/spotless (the showers off/drying out/i will seal/pump the holes with silicone)
Anyone advise please.
Shower has all dried out, so the vertical gap can now be resolved, juts not sure how i can get a 'sealant' in between the tiny gap?
Or do i just glue a strip of white plastic 'make-up' over it and silicone each side of that?
I presume they are tongue and groove and should have been siliconed on installation, however.
Me personally to fix this I would clean it all up with isopropanol then force in Dow Corning silicone sealant and clean up the face with a fugi sealant tool.
Then final clean of residue with isopropanol.
So get this -https://www.NoLinkingToThis/p/dow-785-sanitary-sealant-clear-310ml/38292
and cover the joins, then force it in with a fuji tool (i have a copy one), then clean any excess sealant up with isoprop? I never new it would remove excess wet sealant! I suppose a rag just lightly soaked in it will remove it??
It will all be cleaned down, i will spray with isoprop and try get a rag/kitchen roll so it's spotless before i start.
I have several tubes of Screwfixes No-Nonsense clear silicone, why do i need the Dow Corning one?
They are both mould resistant and both contain the same chemicals when i just checked -
Contains: 4,5-Dichloro-2-n-octyl-4-isothiazolin-3-one
Use what you wish, I just told you what I would do.
After 25 years of people paying me to do this stuff, I go with the products I Know work - other products may work too I don’t know.
Reply to ADVICE -Shower leaking via 300mm UPV panels gap? Best way to seal?? in the USA area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
