Discuss Advice Sought Following Boiler Service in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sro80
Hi Guys,
I am looking for some advice following a boiler service earlier this week. I am not an engineer, just a home-owner. Last year (June 2013) I bought a new build property. Installed was an Ideal Logic Combi 35 boiler. A few days ago I had it services by British Gas for the first service as required.
The B/G engineer serviced and tested the unit and advised it had "passed" however the CO/CO2 emissions were high for a boiler 1yr old (but technically within the limits). He got a reading of 0.0032 (or 320ppm I believe). I have a copy of the original install paperwork and the figure there reads 0.0017.
He suggested I go back to the developer and ask them to investigate why the reading is so high. I did speak to the developer who passed it out to their plumbing contractors. The contractors contacted me and advised that a) it is within limits, and b) the readings can change based on the direction of the wind.
I find that second statement rather worrying. The contractors have agreed to come down but I feel I will be fobbed off.
With regards to the readings, is this something I need to be genuinely concerned about? Any advice for handling (possibly awkward) contractors?
Many thanks in advance.
S.
funnily enough its bg you should be going back to to see whether they just carried out a safety check or did they actually service the boiler. That is, did your technician take analyser reading, note they were high, pop open the burner comp to see it was all clean and dandy, reassemble it, check the gas pressure to the boiler, run it up to working temp reanalyse the boiler, carryout calibration adjustment to the gas valve to ensure it was running at the correct CO2 levels and CO levels and hand over a working boiler fit for purpose. So now you know what to expect prehaps you should employ a gas technician to carry out a service rather than relying on bg to do a safety check and try and blame a developer for something that is nothing to do with them!
Got nothing to do with the contractors as bc where the last to touch it and why take a bg policy out on a new build house when the boiler will be covered by manufacturers warranty and all other works will be covered by the developer for a period of time
only if it has an annual service!
If you dont have anual service then warranty void, but sounds very much like the original installer didnt set the boiler up for a start, but whether he did or didnt british gas have took your money and shouldve checked all gas pipe sizes and pressures as last one at the boiler so it falls on there shoulders im afraid, but if its a new install there SHOULD be a benchmark book as well as the installer form of saftey checks to look at and see what was done on instalation completion,
BG just did a flue check. Typically a logic is 0.0011 to 0.0020
Probably full of dust and debris from construction site. Did the engineer strip the boiler and pour water through it? This is what the manufacturers instructions tell you to to on service.
Recent new property hmm so it might be covered by NHBC - or are they defunct
Chking
To clarify, I contacted B/G to have them carry out an annual service (didn't notice him pouring water through the unit). I do not have a maintenance contract with them. The engineer did the service (gas pressure check etc) and not just a safety check. When he noticed the "high" readings, he checked various items and then he contacted a colleague and the technical people at Ideal (with me in the room) to try and identify the cause. They went through various checks with him, which he had already done as part of the service, but did them again however they were until to identify the cause of the "high" readings.
B/G wouldn't do anything further beyond the service as I don't have a maintenance contract with them and as the boiler is still under warranty I was advised to go back to the developer to "request investigation into the high readings".
I am not looking to blame anyone here.
If the fan didn't come out and water didn't go in I would be asking for my money back. Read the instructions for the boiler it clearly shows how to service it. BG are required by LAW to follow these instructions. They don't because they are above the law.
Why not get the manufacturer to take a look if it's under warranty. Surely that's what it's there for and they should be able to establish whether appliance fault, incorrect servicing or installation fault.
Reply to Advice Sought Following Boiler Service in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
