Air in heating g system - Already had two plumbers fail to diagnose.
View the thread, titled "Air in heating g system - Already had two plumbers fail to diagnose." which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hi all,
Hoping you can help me out.
We had building work last summer and added a few radiators on both ground first floor. We also replaced our vented hot water system with an unvented hot water system but the heating remains open with a small F&E tank in the loft.
Since the works, when the radiators come on (they are on smart Honeywell Evohome TRVs so open and close on demand) there's a lot of gargling noises from the radiator even on the ground floor. There is also a lot of annoying tapping of pipes around the house that we never had prior to the works. Finally, there is a lot of air in the radiators but I've addressed that by adding the automatic bleed valves although I'm well aware I'm only masking the problem.
I have attached two videos. One is of the F&E tank in the loft showing air coming into it. The other is the recording of the gurgling noise from a ground floor radiator when the TRV opens.
One plumber just suggested the obvious that the radiators need bleeding which I'd already done. I've put automatic bleed valves on all the radiators since I was having to bleed them every other day.
The second plumber was more thorough. He noticed a problem with the installation of the new unvented tank that meant a valve that should be open would close when the boiler overran which he thought could be the cause of the problem. We fixed that but the problem remains. He also tested the water for any contaminants which came back negative (although it did confirm the system has no inhibitor which I need to address) . Finally, he pressure tested it to make sure there are no leaks.
I put a camera on the F&E tank and noticed that every time the boiler fires up (assume also the pump) there is air being pushed into the tank. I have attached a recording if it helps. On the plus side, over 3 days no water was required to top up the tank so hopefully, that means there's no leak.
I'm not sure if it's relevant but one of the new radiators on the ground floor never really heats up. There's no air in it and I removed the TRV to eliminate the possibility of it being locked. The pipe supplying the water get's hot but the pipe exiting the radiator remains lukewarm at best. I've tried opening it all the way up and then closed it slightly each day but it makes no difference. I'm wondering if the is a blockage on the return and I'm wondering if that could be related to the air in the system. My logic is the pump fires up and is immediately met with resistance which causes the burp in the F&E tank. There's no science to my logic so may be complete nonsense.
Lastly, the condensate pipe on the boiler (Worcester bosch 32 CDI about 18 months old) does seem to be dripping constantly when running. My understanding is that it should fill to a specific level and dump the entire lot rather than have a slow drip. Again, not sure if it's related but thought I’d mention it.
Any thoughts?
Thanks in advance
  • FandETank.MP4
    1.7 MB
  • RadiatorNoise.MP4
    6 MB
Hope the system is back to normal, just a bit curious about your method of purging the system, did you just shut both rad valves, remove one end of rad tails at rad, attach hose to the rad pipe tail , reopen valve and purge back through the flow or whichever you opened?. did you just put a bung in the rad opened end while doing this or did you attach to the rad itself and then purge back through the rad and the opposite tail?
Also some time when you get a chance can you see if this bubbling in the F&E tank has now stopped on pump startup or stop.
Reply to the thread, titled "Air in heating g system - Already had two plumbers fail to diagnose." which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Quinla01,
John.g,
