Discuss AIR in secondary loop in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wildcard
Keeps spluttering at taps,was thinking of fitting an aav.Also one of the showers bangs randomly possibly air again.Is there a prob with fitting a aav to the loop?
Cheers
Question is how's that air getting in there and could that problem be solved
No dont use AAV, is this a new install or a repair on an old one , in other words has it ever worked correctly ?
+1 to sort the problem dont mask it
Unvented the system is 12 plus years old he got a lot of problems when the bronze pump was changed.
fitted the right way round?
Did you bleed the pump? To be fair though mains pressure water or balanced from an unvented cylinder should clear of air within a minute.
Yep , right way round as shaun says , is there a nrv fitted if so is it the right way round ? is it working ?
Does the cylinder have an internal or external expansion vessel that needs re-charging? Trying to think of the simple basic stuff.
There's a nrv that rattles like a gooden & and an internal bubble not mega flow but no dripping from the tpr valve
Check the non return.
I gave seen double check valves used to prevent back flow! The secondary pump can't clear the air, as it can't open the non return. Thus also burns pumps out quickly.
Needs a very lightly sprung non return.
Reply to AIR in secondary loop in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
