Discuss Air Testing Equipment/tools Question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lucasgor88
Hello.
I looking for the best tools/equipment to air test a system? What would you suggest to use?
Many Thanks
Just fyi you can't go above .5bar with air so won't test much
its a new system with all new copper pipe been fitted to the cold water tank in the atic to cylinder. :). Tho it be best to test with air make sure there is no leak before i test with water :)
I've used it, but when i put what i search in and pick the post that relates to the topic. It keeps asking me to sign in but im already signed in :/
Reply to Air Testing Equipment/tools Question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
