Discuss Air to water heat pump advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lenny
Hi
Due to popular demand , starting to look into air to water heat source pumps. Can anyone recommend a model / manufacturer who may also train please ?
Lenny
I think you are doing a good thing going into renewable energy. The market will grow, so those that are first in there have the best chance of doing really well when green energy becomes the priority for business. I used to work at Greenworks, they supply a wide range of air to water heat pumps, not sure whether they provide training though.
Reply to Air to water heat pump advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
hi everybody i need some help please, i can't remember how to adjust the temperature setting in heat mode on my dream air source heat pump does...
2K
Mike marks
M
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
I'm planning to get an air source heat pump (ASHP) installed and I'm considering my options about the location of the water cylinder as I live in...
2K
Air entering central heating system and hot water pumping over into make up tank in artic when h/c control is switched on. There is no problem...
1K
