Discuss Airing Cupboard Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bob the bridge
The hot water cylinder in my airing cupboard has now been there 20years. No problems with it, but is it a possibility that sludge or silt might have built up over the years? Should I consider draining it down and flushing it out or is it best left alone?
Grateful for any comments.
If you are in a soft water area, unlike to be any problems.
If you are in a hard water area, could be a layer of lime-scale at the bottom. If its not causing any problems (e.g. frequent changes of immersion heater) I'd leave it until it does, if ever.
If there is a lot of lime-scale, its usually loose flakes. If you have an immersion heater, its often possible to isolate the cold feed, drain the cylinder if its a low level fitted heater, remove the heater, and suck the loose lime-scale out with a wet and dry vacuum. The replace heater and re-fill.
Ok Many thanks
Reply to Airing Cupboard Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
