Discuss Alpha cb24 problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nabby 68
Hi
got a problem with an alpha cb24, I have no hot water at all even when I've set the control knob to hot water only. How do I check to see if it's the flow switch or diverted valve or diaphragm.
is Alphaman about!
thanks
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Hi
is Alphaman about!
thanks
PM a mod and they check you are GS registered, there is another section of the forum where boiler repairs are discussed.
Reply to Alpha cb24 problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
M
Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took...
