Discuss Alpha Range with Periscope Burners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Soggy
I have worked on several of the newer Alphas but never an older one (96) with these burners. The previous service records show that they have had problems getting acceptable readings, with both burners being set at between 6 and 8% CO2 and 120-260ppm of CO. Before I get stuck into it, does anyone have any experience or advice? Nozzles used are 0.75 80W and 0.4 80W
Not even heard of them. Is it some sort of range? Yes it is, just had another look at the picture and seen the labels on the burners.
Stopped doing ranges. Not worth the hassle.
Be interested to hear how you get on.
worst case treat as a rayburn, co2 would be more like 11% on my mind to work properly, if they are stanley alphas then aga took them over and should have tech knowledge
I have the manual, and indeed it gives a CO2 of 11-12%. For some reason, the previous service company have not been able to achieve close to these figures.
Reply to Alpha Range with Periscope Burners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
