Discuss Any idea how to get the top cap off this tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
bensaunders
I can't work out which bit unscrews - I'm guessing it is either side of the two ribs but if someone knows it will help me decide where to give it some wellie!
Almost certain it's just above the 2 ribs.
Palm of your hand (maximum contact) and push down and twist.
Have you tried just pulling the top off ? had other taps like this , takes a bit of patience and wriggling about but they will move .
Very top section unscrews. the rest will be obvious. If it doesn't move easily gently tap round the top ring. It will eventually move.
Had one like it last week, was solid! A rubber glove & pouring boiling water over the top did it
Either prise off with thin flat screwdriver, carefully.
Or some rubber gloves and grunting.
GasSafe & Simon G are spot on. The threads become gunked up with soap and rubbish. When reassembling use a little silicone grease on the threads.
Had a tap like it the other day, took me a few minutes to get it off, cannot remember how it came off though.
But I would use a persuader on the spout if needed but protect spout first, and try and unscrew it.
Top cap just above the rings unscrews
Just the top cap. But if it has not been touched for years it will be solid. I use a soft cloth to protect the cap and a pair of grips to turn it. But be careful, if you don't use the cloth you will scrape the chrome
A few tips for removing those top caps, -
They are very rounded, so not much to grip on, but try a strap wrench that has a rubber strap.
First tap the cap gently a few times with a rubber mallet, or rubber coated handle of your hammer or pliers to hopefully unseize the threads.
Put electrical insulating tape around the edge of cap and do it so that it is rough, folded up way - that will make it so easy to grip with your hand and is a brilliant way to try to remove any parts on taps
As the original post was last November. I'm sure the poster has sorted if. :cool:
Reply to Any idea how to get the top cap off this tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
