Discuss Any Ideas - Tempra 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
skaly
Hi I was called to a Ferroli Tempra 18 When turned on from cold it had been running for 1 minute then off 1 min then running 1 min and so on, that was for the last few days but today when i got to it it ran normal, I ran it at max turned down temp it went off turned up temp it came on and ran fine. ANY IDEAS as to what it could be .
You need to check the heating ntc to see if it in range, then if ok checkto see if limits are kicking in, F &R temps,also flue/aps related issues.
Reply to Any Ideas - Tempra 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I've got a testo 327-1 that I purchased back in 2019 when I went self employed. The analyser hasn't been calibrated since purchase. After...
