Discuss Anyone got a shires u85 toilet siphon for sale ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This really old shires siphon fits into a bottom well cistern and the tail swivels underneath the "chamber". Dudley S and Macdee D shape too large.
Can't find it on-line.
or switch to the push button
I would just mend the one you have if nothing else will fit. The worst is if a seam weld in the plastic has opened up, this can be remade with judicious use of blow torch if you're brave, or these days try CT1.
Thanks - this is what I did. the thread connecting the syphon to the swivel section that puts the "out" pipe under the syphon was cracked. I mended with araldite rapid and it is OK for now, but don't know how secure araldite is under water. If it doesn't last I may replace with a flowmaster duoflush which has a lever option on the end of a cable. |I could drill trough the side of the cistern at the top to fix the lever in place.
This is taken from snowhead's link;
1.5" outlet size Dudley Turbo S1-11 easy maintenance syphon available in two sizes. 9" spillover or 10.5" spillover height. These syphons are designed to fit narrow cisterns or the older high level well bottomed cisterns. Please be sure to select the height of the syphon required.
For some reason puts me in mind of my lovely wife....
Thanks for this. Unfortunately the Dudley S1 is too large by about 4 cm. The cistern is an antique - could be 70 years old connected with lead pipes (Shire Uni-Lynx), and I think the syphon was specially designed to fit. Its a neat design with the syphon chamber actually sitting through a swivel over the out pipe.
Thanks for the info on the araldite - keeping my fingers crossed.
Won't a flapper get in there? They have a small footprint.
Thanks - Yes - A flapper (Flowmaster with a lever) is my plan B if the current one pegs out. Thanks also for the Dauntless info. I'll see if I can get the distance from the middle of the "out" pipe to the edge of the housing. It looks similar to the Dudley S1 which is too big. Cheers.
Reply to Anyone got a shires u85 toilet siphon for sale ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
