Discuss Anyone seen one of these plastic couplers on WC before? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi everyone,
I'm in the process of fixing an old Twyfords WC. It is a close-coupled model, though with an unusual plastic elbow between the cistern and pan. See pics.
Anyone know if/where I can get a new elbow?
Thanks for your advice,
Jennie
That is an adaptor to take a close coupled toilet cistern into a pan that would normally be used with a high level cistern.
I beat you to it! Glad someone else knew what it was though because I could not initially remember what it was called.
That`s what took me so long, couldn`t remember either so went surfing. :p
This is my opinion bin it and change the toilet
I've changed that many of them it's silly (county specd them in disabled toilets )
Hi everyone. Thanks for looking up the part. Expensive and leaks. Hmm. Reckon I could hang the cistern on the wall (with some brackets) and convert it to a low-level toilet, with 1 1/2 to 2 inch tapered flush pipe? Would a standard rubber cone fit into the back of the pan?
Too close and also would need to mounted a bit higher so cus normally doesn't like it
I can hang it higher (any height really). Just as long as the horizontal bit of flush pipe can fit into the cone/pan. (I'm fixing it for a family member who is on a tiny budget, and also wants it to stay as it matches the basin colour. For a customer, I'd be fitting a new loo).
If there happy mount it higher happy days
Those toilets were designed to suit where you had to replace an old low level toilet which had the soil pipe going into solid floor and not easily to move.
I never had bother with them, but they are a bit flimsy in the connection bend to cistern.
Reply to Anyone seen one of these plastic couplers on WC before? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
