Dava811
Hey all,tried to fix a friends shower recently. It's the named shower above.
It runs for about 30 seconds then it seems to click and turn itself off. The blue light on the front of the shower no longer lights up at all and it used too. Once it cuts out I can turn it straight back on and it does the same, checked filter,made sure isolation valve on supply pipe fully open. There is some kind of float valve coming from a little silver cylinder inside the shower,once it clicks down the water stops.
Thanks in advance..
Thanks in advance..
