Discuss Are designer, column type radiators bi-directional? in the Central Heating Forum area at PlumbersForums.net
Jock Spanners
Evening all,
A customer has shown me some designer, flat column type radiators she wants me to fit. On the bottom they are marked 'in' and 'out' which I assume means flow and return. Does anyone know if it makes any difference which way the flow and return is connected? I don't imagine it does but can't understand why else they're labelled as they are.
Thanks,
Jock
Yes it does have to be as labelled as there’s baffles/ diverter
They can be a real pain, are you able to swap them over somewhere else, say floor above or near boiler? Obviously only an option if they're all wrong.
Reply to Are designer, column type radiators bi-directional? in the Central Heating Forum area at PlumbersForums.net
Hello all, I live in a flat that has communal heating through a single pipe system. I recently had replaced a deco flat panel (waffle) radiator...
Morning all, I have a Worcester Bosch 8000 life 40kw boiler on system with 7 radiators and the boiler is located in the loft of a 1907 end of...
Simon from Watford
I have recently had this radiator fitted and currently it gets very hot. I would like to turn the radiator temperature down however I'm unsure...
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below...
Hi - we have had new radiators fitted about 6 months ago ("DuraTherm Horizontal Double Flat Panel Designer Radiator" from plumbworld - sorry, this...
