Discuss Are kitchen sink apertures a standard size? in the USA area at PlumbersForums.net
We have a one a half bowl sink in a standard 100cm base unit. We want to replace the sink with a new one a half bowl sink in the same worktop. How likely is it that the new sink will fit in the same aperture with little or no cutting?
There's no standard as far as I am aware and I've fitted and replaced quite a few sinks over the years. If you can find an exact fit which might take a bit of luck, great, but it's usually possible to find one just a few millimetres larger one way or another and fit that which does of course require a bit of cutting.
Even if there was a true standard size, like so many measurements in construction and materials, it will often be a "Nominal size" rather than exact.
The size of the cutout is what's important here. Measure from underneath if possible or measure from above but remember to take the lip/flange into account and see if you can find one of the appropriate dimensions. There are so many out there you will find one to fit with little or no cutting if lucky. Nothing beats having an exact measurement of the hole in your worktop and going out to a merchant or two armed with a tape measure to see if you can find a good fit.
Unfortunately there's no exact, straight answer to this one.
Reply to Are kitchen sink apertures a standard size? in the USA area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
