- Messages
- 5,439
Ta muchly
Discuss Are the femlale connectors on bar mixers 3/4"? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Horrible things those offset connectors.
I always use these type of fittings now.
Bristan Bar Valve Wall Mount 10 Fixing Kit Chrome-Plated | Shower Spares & Fittings | NoLinkingToThis
Nice! like your thinking there ermi, you had similar problem before?Cut tube tight , 1/2 sticking out of wall. Put end feed cap on , drill out center with 8mm bit. Go to orange shed. Pick up their own brand tile hole saw. Set up 20mm one. Use end cap with hole for center and drill tiles round pipe so u have space round it. Remove end cap, sweat on iron. Tight as owt!
Reply to Are the femlale connectors on bar mixers 3/4"? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
