Discuss Are these pipes acceptable? in the DIY Plumbing Forum area at PlumbersForums.net
We had a leak from our boiler which meant I had to take up the flooring. This was a bathroom, but we want a utility room, so will be putting in the washing machine. I don't know if these pipes are accetable though? We need the water feed (on the left) and the pipe for the waste (you can see on the right curving behind the boiler pipes). The waste pipe is 22mm OD.
This is part of an extension at the front of the house built by a prevous owner, the pipes dissappear under what used to be the external wall.
They look fine would clean all the rubbish out under the floor tho
I never really thought about this but can I pick your brain.
If I hadn’t read your post, I would have advised against connecting a washing machine discharge to an overflow pipe.
Wouldn’t the increase in friction of the overflow pipe compared to 1.5 inch waste, cause issues with the washing machine pump?
It’s one of them bigger always better but if it’s only a short run it should be fine and it looks like one was connected there before left hand side washing machine point
Well, i'm not sure if it is a short run. I'm not sure where they go once under the wall. The kitchen and bathroom are at the back of the house, as are the drains I believe. Thats 10m back and 5m across.
Where does the boiler condense go into ?
I don't like the look of the the way the ends of the joists are being supported. The piece running left to right looks undersized to me and I can't see where the load is being transmitted to. If you put a washing machine there the joists are going to get a regular thumping during the spin cycles.
Reply to Are these pipes acceptable? in the DIY Plumbing Forum area at PlumbersForums.net
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Hello all I have had an extension built which will have 3 radiators to the big main room, a utility sink and a shower room (ground works, waste...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
