Discuss Ariston e-combi 38, Pump constantly on in the Gas Engineers Forum area at PlumbersForums.net
MaksimsK
Hi, could you help me to solve mysterious stuff happening with Ariston e-combi 38 located on the loft
  • Can hear the sound of the boiler pump in our bedroom. If I come closer to the boiler, it's not sound so bad, but in bedroom you can hear it a lot.
  • pump is running even with room stat turned off. Could run for hours. But sometimes can stop for no reason.
  • separate thermometer near roomstat shows 22, stat set to 17. Boiler is kicking in.
  • some of radiators is not heated evenly, only top. Actually 5 from 7.
  • shows the error: insufficient circulation
Any ideas?
Replace pump, sludge - powerflush... Those were my thoughts
If the pump is running need to look at what’s controlling it eg do you have switch feed into the boiler if not I would be looking possibly at pcb
Reply to Ariston e-combi 38, Pump constantly on in the Gas Engineers Forum area at PlumbersForums.net
Hi, I am currently having issues with an Ariston Combi A series boiler giving an E08 - "No water in primary circuit" error code, the circuit is...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
I have a conventional system, Potterton Prima Boiler, into a Pump into a Motorised Valve that feeds the Radiators and/or the pipes in the Hot...
Hello forum, 1st time here. The Grundfos 3-speed pump in a Worcester Heatslave 15/19 oil combi boiler is on its way out. The boiler is old but...
I have a Combi boiler and, a few minutes ago I turned on the hot tap in the kitchen and the water was far from hot. In fact, it was decidedly...
