Discuss ariston eurocombi sx 20 mffice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Any help please with the above combi, had a problem with tandem controller, this was changed and since heating works ok however, the hot water supply does not get hot, only on very slow flow and then only hand hot, and running so slow unable to use shower, the heat exchanger removed and no blockage.
You need to register as a member however what does you gsr engineer say or if you have lost faith in him then repost saying where you are and there may be a gsr guy here local to you.
Reply to ariston eurocombi sx 20 mffice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
HI Iam hoping someone can provide guidance on a heating problem. I have a (old) Ideal isar HE35 where there is no hot water for the 2 showers at the property, there is water flow but not warm. I can confirm there is hot water from the sink/bath (downstairs and upstairs). I noticed that the...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater systems in the house. This boiler was replaced by a combi boiler as it only heats the lounge and master bed and provides hot water to en-suite bathroom and...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for heat, the boiler fires up, modulates, but jumps very quickly (about 30 seconds or so from 40'ish all the way to 70, burner disengages putting it the...
Hi everyone, New here & my first post! I have a Worcester greenstar 24i, it is a conventional boiler, it has a water tank upstairs. For the past year the hot water when turned on was intermittent. I repressurised the expansion vessel to 1 bar and the hot water switch when turned on worked...
2K
