Discuss Back Boiler Not Heating Water But Heating Rads in the Central Heating Forum area at PlumbersForums.net
Hi Guys, I've got a woodburning stove with a back boiler that I cant quite figure out. Last year it was heating the water but not the radiators, and this year its heating the radiators and not the water. Does anybody have any ideas? Its a fairly old installation, I'm guessing from the 80s ish, in a 70s house in the highlands of scotland.
There is a gas boiler, which is currently switched off, and an array of pumps and thermostats. Theres a thermostat next to the gas boiler, one in the hallway, one on a pipe beside the water tank in the attic, and one on the water tank itself. Theres a pump downstairs beside the stove, which is running. And one in the attic near the hot water tank which is switched on but not running. There seems to be a honeywell valve near the attic pump which switches between auto and manual, but neither seem to make a difference. There is a header tank in the loft space above the hot water tank (with water) and a smaller tank near to it (which i havent checked the level of). When the immersion heater is on it only heats a small portion of the water tank capacity. Perhaps this means there is an airlock? Any other ideas. The stove is absolutely belting out heat and it has worked in the past heating both the radiators and hot water so i'm confused (which is nothing new).
Cheers!
Looks like you have a 3 port valve, but this may be part of the gas boiler installation? If it’s part of the whole installation then this might be failing.
I'm really not sure unfortunately. Is the 3 port valve the grey Honeywell box? That box seems to heat up when the back boiler is heating. There are two positions on an actuator switch; "auto" and "manual". When i switch to manual i can hear some water glug through but not much else seems to happen
Yes the Honeywell box. Manual won’t do anything on that valve, it’s for filling the system, not a bypass for the microswitch. If that heats up when the back boiler is in operation then it’s likely that this does the hot water too.
Great, that sounds like good news. Any ideas on how i can switch from heating the rads to heating the water in the tank?
You could try turning it off on the fused connection unit, which may trigger the valve to return back to hot water position. If that doesn’t work you’ll likely need a whole new valve, as yours doesn’t have a dimple on the metal box, which usually means it’s not serviceable without draining it down.
That sounds like a good plan, I'll give that a bash. Thanks!
Reply to Back Boiler Not Heating Water But Heating Rads in the Central Heating Forum area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate tank. There is a thermostat on this second tank that pushes hot water over to the store tank when it's hot. It's a closed loop and goes through a heat...
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank upstairs in the house. We have an issue where if the boiler isn’t set to 80c then the boiler will short cycle, the hot water tank thermostat is set at...
1K
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any kind of instructions/manual and therefore trying to figure out ourselves. We have what looks like a boiler/water tank system (coming from a standard...
