Discuss Balancing radiators on Heat Pump System in the USA area at PlumbersForums.net
My radiators are fed by a Ground Source Heat Pump. On the balancing advice I have seen, it says to have a 12 degree difference between feed and out on a normal heating system.
My question is because the boiler runs at a lower temperature than a normal boiler, what temp difference should I be trying to set?
Reply to Balancing radiators on Heat Pump System in the USA area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
