Discuss Ball valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A couple of days ago I arrived home to find water gushing out of the over flow pipe from a tank in the loft. I rushed up into the roof to see the water level in the central heating tank level with the top of the tank and cold water at full boar.
after turning off the cold feed I discovered that the plastic ball had snapped of the arm . The arm had dropped down allowing full flow into the tank.
how could this have happened , has any body come across this before
plastic goes brittle with temp and bet the pin had snapped
Thanks for the comments . I see what you say about brittle plastic . The valve to my knowledge is ten years old. What do you think of this theory. The over flow pipe is quite close to the top of the tank. If the washer was leaking do you think that the slow rise in the water level Could exert enough pressure to snap the ball before the water reached the over flow
The float may have been older than the valve, no real dramas .
If you have hot water getting into the tank by pumping over at times, then that also would damage plastic. But everything is a bit delicate nowadays and usually made cheap. The brass pins can rot, but never have seen one snap yet
Thanks for all you comments , but I will be keeping a close eye on it from now on .i think with tanks in the loft it's a case of out of site out of mind. Townfanjon. No real dramas cheeky. Had I arrived home a couple of hours later I would have had a major flood. The flow of water into the tank was greater than the overflow could cope with thanks again.
Reply to Ball valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
