1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Dismiss Notice
Couple of important things to note. 1. We use Cookies, deal with it. Every website does. 2. Nobody but a currently-registered Gas Engineer should be touching gas or gas appliances. Don't mess with gas at all.
Discuss Ballcock now driving me nuts in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. DripsnDropsBognor
    DripsnDropsBognor New Member
    So i fitted new combi cylinder last year
    and replaced ballcock in tiny cold water storage tank at same time.
    Bank holiday weekend went over and changed both ballcocks both tanks share 1 overflow.
    Both shut off happy days.
    Phone call day to say water is ****ing out of overflow...
    Been over tested both ballCocks all seem fine bent them a tiny bit more just to make sure they shut off hard.
    Just had another call to say dripping again outside.
    Also noticed today top tank in combi was warm water to touch... think this is just conduction or thermostat failed?
    Any ideas?
  2. ShaunCorbs
    ShaunCorbs Trusted Plumber GSR Top Contributor!!
    combi boiler on a non pressurised heating system ?
    or do you mean a cylinder
  3. DripsnDropsBognor
    Combi Cylinder economy 7
    Cold water tank in top cylinder in bottom part
  4. ShaunCorbs
    right its a fortec cylinder
    any outlets that have hot on mains ?
    eg mixer taps showers etc
  5. DripsnDropsBognor
    Hot on mains? Hot and mains would only be kitchen sink... everything else runs off c/w tank and cylinder boosted my shower pump
  6. ShaunCorbs
    boosted both hot and cold if so put some check valves on the kitchen sink
  7. DripsnDropsBognor
    You think mains is back filling cylinder from kitchen tap?
    Hadn't thought about that...
    More likely with showers tho no?
    Failed stat not more likely and backfilling that way?
    I need to go back and check...
  8. ShaunCorbs
    yea
    if there pumped equal pressures so not likely
    not after a year but worth checking but top tank would be warm
  9. DripsnDropsBognor
    Thank you very much definitely food for thought I will investigate both. I have had a few dodgy backer elements around the same time I fitted cylinder so need to triple check it's not backers I fitted
  10. Chuck
    Chuck Top Contributor!!
    Assuming you mean a 'Fortic' type combined cylinder...
    If the hot tank starts filled with cold water at, say 10°C and heats up to 60°C the water will expand by about 1% by volume. This amount of water will be driven up into the header tank and there needs to be space to accommodate it without the overflow running.
    If there is not enough expansion space the process will continue until the cylinder is full of hot water, a couple of litres will overflow in the process, and the header tank may have got somewhat warmer than normal as well.
    For a combination tank, normal expansion [0.02%/°C for the bulk expansion coefficient] is only going to raise the level in the cold tank by 15 mm or so. If the thermostat has failed (and there is no other cutout) the expansion will be proportionately more up to the point the temperature in the cylinder reaches boiling at which point a lot of steam will start being transferred up the vent and then out of overflow, with the rate limited by the heater power.
    So, if your top level is at least 15 mm + plus a bit for luck below the overflow and the ball-valve seems to be working well I'd suspect the thermostat.
    If it reached the point the cylinder was boiling I think it could be pretty noisy, dramatic and dangerous. I've never witnessed it myself. I have seen the aftermath of such an incident (in the 1970s) when a boiler hadn't cut out, the overflow hadn't coped, and there was a *lot* of damage to the house. There would have been a lot more power than an electric immersion heater but I've erred on the side of caution with thermostats ever since.
    • Like Like x 1
  11. DripsnDropsBognor
    Yes fortic cylinder type...
    Thank you I will investigate in the morning as I am paranoid about cylinders causing damage.
  12. Gasinspect
    Gasinspect New Member
    I was always taught that Fortic needed copper float, not plastic. But kitchen tap if it is not divided flow in the spout could cause problem of backfilling. doubt it is a failed stat, you would soon know if that was the case!
    • Like Like x 1
  13. DripsnDropsBognor
    So no problem with fortic tank. Ball valve in there is fine.
    My problem now is with ball valve is tiny cold water storage tank.
    I have put 3 fudging ballcocks in it now and when left to its own devices it over flows. There is only 6 inches of water in it when I have fitted I wait for it to fill and stop which it does perfectly. However after 24hrs the overflow is dripping again...
    I know what I'm doing with ballcocks I have probably fitted 300+ but what is going on with this one?
    Can it be that I have fitted 3 faulty ones.
    1st one from my local regularly use and 2 from different suppliers but nothing solving so far. What else could it be?
  14. ShaunCorbs
    Are you sure it's the ball cock and not rising through the feed or vent
  15. DripsnDropsBognor
    Customer can hear constant dripping in cupboard and it is supplying cold water to toilet basin and shower. no vent pipes going into it... it has fortic cylinder next to it.
    I don't think it can be back filling from anywhere as all seems equal pressure.
    I have noticed mains pressure is only around 1.5 bar is this high enough pressure for high pressure seat?
    Could it be that part 2 ball valve is just too long and can't be adjusted enough to turn itself off and I need to fit a part 1?
  16. Chuck
    Is the static water pressure very high or very low? Is it within spec for the ball valve?
    What make of BV are you fitting? Are you sure it's a genuine one and not some fake that's come out of a Christmas cracker?
  17. DripsnDropsBognor
    2 peglers fitted
  18. Gasinspect
    Send a photo of the setup, and diagram of what it is supplying.
  19. DripsnDropsBognor
    Pretty sure
  20. DripsnDropsBognor
    Not piccys.Not going back now until 20th may customer off on holiday... alright for some eh.
    But pretty basic 2 bed flat. In airing cupboard combined cylinder (fortic) hot water only. Hot feed to shower and basin in next room then kitchen behind that room.
    Small water tank located above cylinder cold water supplying basin and shower.
    All feeds from both of these go through Stuart Turner shower pump to get to outlets.
    Mains feeding tank and cylinder and cold kitchen tap.
  21. zzzjim
    zzzjim Well-Known Member
    Is water nice and clean , ( put some temporary flexis with ISOs to confirm
    blame on peglers miss-behaving ?)
    Is there much vibration in the area ?
    ..or am I off my trolley..
    • Like Like x 1
  22. Gasinspect
    you say "mains feeding tank AND cylinder" - ??? I hope you mistyped that, if not, then that will mean problems.
    Otherwise, check that there are non-return valves on supply to shower mixer.
  23. DripsnDropsBognor
    Fortic cylinder so yes mains feeding top half of cylinder which feeds hot water part.
    Not typo
  24. DripsnDropsBognor
    Water nice and clean no vibration present. Was worried it was spinning on tank but definitely not.
    Was burst main down Street but been repaired now.
    Could be down to this? Highly doubt it going back on 20th... think I might try part 1 just to see if it is length of arm in tiny tank that is causing me ****.
    I seem to remember there being a part 1 fitted when I first replaced 18 months ago thinking it was odd because tank is fairly new.
  25. zzzjim
    Was thinking mystery crud , causing valve to pass . Disturbed by vibration .
    (inspect rubbery bits ! )
  26. Chuck
    There should be a lid on the top of the cold tank. Could it be sagging and stopping the float rise fully?
    • Like Like x 1
  27. DripsnDropsBognor
    Lid off lost behind cylinder shhhh! No-one knows!
    Have checked all rubbery bits but to no avail.
    I think maybe the pin was too stiff for shutting off naturally as I can shut of with my hand. By lifting arm literally half a mm from where it was dripping.
    Maximum adjustment bending and float placement leaves 6inches in bottom of tank and still dripping...
    Still thinking part 1 is only way as tank is so tiny and arm is shorter on part 1
  28. zzzjim
    Part 1 may seem a backward step , but if overflow makes it safe from syphoning ,
    may be way to go . Seen excessive pressure damage new style stuff in a jiffy .
    • Like Like x 1
  29. Chuck
    Have you got the right type of float on the valve? If adding a small amount of uplift with a finger shut the valve it suggests that you need a larger ball. Anyway, Pegler has an office in Yorkshire and advertise a technical help service. If you've bought three of their ball valves and they aren't working as you expect try calling them and see if they can put you straight:
    Technical Help
    Free Phone 0800 156 0050
    Free Fax 0808 156 1012
    [email protected]
    Disclaimer: I've never tried calling them myself, I've never had any problems with their products.
    • Like Like x 1
