Discuss banging air? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sym
When our heating switches off we get a very loud banging noise from our system. It only happens on the heating. The pump is installed so that it pumps down, is it possible that air produced by cavitation by the pump is released when it stops and causes the noise.
boiler kettling possibly if ch pump doesnt have an overrun facilty and hot water is on a gravity primary to coil in cyl so can continue to circulate if boiler goes off.
Could do with checking that the pump runs on after clock turns off. If not check there is a permanent live feed into boiler. If ok or maybe even still change the boiler/overrun stat, as it maybe out of calibration.
Is the boiler noisy when running [ kettling sound ] , also check rads when heating if cold spot at bottom middle, system needs flushing, pref power & chemicals.
If boiler just kettling, can add sentiel x200 or fernox F2 noise reducer [won't cure, just like taking cough medicine, it'll be better for a while!]
Another thought, if it's just 1 loud bang on shutting down check your motorized valves.
Reply to banging air? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hi I'm dealing with Vaillant Ecotec 824 R1 in one flat. The boiler make a very loud noise when central heating is on - this is random and occurs...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
