Discuss Banging boiler with embers? in the Gas Engineers Forum area at PlumbersForums.net
I turned my central heating on for the first time today this year and it started to bang and the flame inside looked a bit erratic. Upon looking in the pilot light viewer it looks like there is debris/embers burning resting on the bottom. I turned everything off and switched it back on to check the fault lights and the banging has stopped.
But is this something I should be concerned about and what could the problem be?
I'll attach a photo of the pilot light so you can see what I mean.
p.s. its been on about 1 hrs now without any problem.
Thanks.
your boiler needs a gas reg engineer to come and clean it all out as soon as posable
it should not be like that.
Reply to Banging boiler with embers? in the Gas Engineers Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
