Discuss Banging Clanging Noise from near Boiler/Pipes near it!! in the USA area at PlumbersForums.net
Hi all,Hope Someone can shed any light on the issue we currently have. Last week the water company were working in our area ( though they never told us initially) and we only noticed and raised the issue as our water pressure was really low. Anyway long story short they completed the work in our area and called to say pressure should be back to normal. We now have a strange banging/clanging noise near the combi boiler/pipes upstairs in the cubby hole next to the bathroom that only happens when we turn the hot water tap off in the kitchen ? It doesn't happen when it's cold water from the kitchen mixer tap or from the hot and cold mixer taps in the bath or the sink in the bathroom. Also doesn't happen when shower turned off or on either?? If we turn the kitchen tap on slower and off slower we don't get the banging/clanging noise. Is this water hammer or something else to do with the boiler a Bosch Worecester Junior 28i? I have tried turning the stop tap water pressure down slightly to see if that helps but am at a loss? Any advice-help appreciated
Is it quarter turn type tap?
Sorry to you mean the actual tap in the kitchen that causes the issue? If so it's a large mixer tap ...attached.
I just find it strange how we didn't have this issue until after we had the water pressure issue when work was being carried out.im wondering if its a pressure issue?
Pressure might be a bit higher than it was. Try Al's suggestions from the vid - look for loose pipes etc. Unlikely to be related to the boiler
Will do mate. I'll turn the stop tap off completely tomorrow then turn it back on gradually until I get a decent flow rate and see if problem still exists. Strange how the tap (the only item doing it ) is furthest away from the boiler and it's only the hot water???
I've attached a video of the noise I've recorded ..pipes or boiler ? Filmed in cubby hole on the landing where the boiler is installed 7-8 seconds you can hear it .
# I cannot add the 20 second video in mp4 format ??
OK so I have turned the stopcock pressure down by a quarter turn then another quarter turn but still get this noise near to the pipes near the boiler or from the boiler only when hot water tap turned off after being initially turned on in the kitchen only?? Any other ideas anyone?
  • 20211029_122802_1.mov
    8.9 MB
Turn the tap off slowly need a shock arrestor fitting
Yeah I've tested it again Shaun and it definetly doesn't happen if you turn it off slower (the kitchen mixer tap). What I don't understand is this didn't happen until we had initial lw water pressure problems ( unitised utilies were working in the area). They told me to do the "turn off water mains/stop tap,turn on taps on 1st floor,then ground floor allowing all water to drain then once drained turn stop tap back on allowing water to flush out any air". They said could be water hammer!
Where would we fit the shock arrestor specifically?
Is it dangerous ?
Reply to Banging Clanging Noise from near Boiler/Pipes near it!! in the USA area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
In our sealed Megalo system, when hot water tap is used (say in bathroom shower) the megaflo is taking in some fresh water, I guess to compensate...
Hi I'm dealing with Vaillant Ecotec 824 R1 in one flat. The boiler make a very loud noise when central heating is on - this is random and occurs...
We have recently had water hammer issues. Plumbers have installed an arrestor near our kitchen sink and a device in the toilet cistern to slow...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
