Discuss Bar mixer shower - unable to adjust temperature in the USA area at PlumbersForums.net
I have a concealed 3 valve thermostat mixer shower which is around one year old.
I realised that the middle mixer that sets the temporary is just going around and not changing the temperature. I’ve removed the knob and found the grub screw has created a groove all around the spindle and the knob is not gripping. I have tried tightening the grub screw but it did not help
I am now looking to drill the spindle a little so the grub screw can sink into the spindle and make a firm grip.
Would this solution be ok or is there any danger of me causing a further problem ?
Any help much appreciated.
You could put a flat on the shaft where you want the grub screw to tighten onto
Hi Thanks for the info. I'm sorry for being a bit dumb but what do you mean putting a flat on the shaft ?
like a or b would do
Reply to Bar mixer shower - unable to adjust temperature in the USA area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
