Discuss Barbers with 4 basins in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Piperdave22
Hi , I’ve been asked to give a price for putting 4 hairwashing basins in a barbers .
There is only a cold mains supply in the property and only electric aswell no gas .
What would everybody suggest for feeding this bearing in mind the basins could all be used at the same time ?
We did hair dressers etc years ago and unless you are in a hard water area...wack in 4 lecky shower heaters cheapest
like triton..riva so you dont need a hot and cold supply ok then .watch out tho get the barber to get the basins up front. as they are expensive and weird..and need fitting over the worktop and right up to the counter frontthen fit at least 1 1/2 inch waste and then join to 2 inch as hair and Rubbish goes down big time....with plenty access points to rod out and if its a succesfull business the shower units will be stuffed after a year...but at £50 straight swop who cares
they will not care cause they are creaming it in
like triton..riva so you dont need a hot and cold supply ok then .watch out tho get the barber to get the basins up front. as they are expensive and weird..and need fitting over the worktop and right up to the counter frontthen fit at least 1 1/2 inch waste and then join to 2 inch as hair and **** goes down big time....with plenty access points to rod out and if its a succesfull business the shower units will be stuffed after a year...but at £50 straight swop who cares
I think you might need some electrical upgrades to run 4 electrical showers together
I've done 4 hairdressers. In three I've ended up going back to fit an additional cylinder because as the business grows one cannot keep up. All have been direct, super insulated, and had regular element changes.
Barbers , how many of you guys with hair actually have your hair washed , guess , not many , I would go small unvented all day long .
Hairdressers totally different .
What’s the supply spec ?
I know that but it will work
4 x 8kw is easy for a decent sparky boy. then the rest is simple plumbing and mitigates any risk
which is 140 amps just on its own
most small places have a 80-100 amp supply
so thats a no go unless they have 3 phase
Reply to Barbers with 4 basins in the Plumbing Jobs | The Job-board area at PlumbersForums.net
