Discuss Basement pump causes sewage smell in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
toadhall
I have a basement pump for my washing machine. The outlet used to go directly into the outside drain but now it is linked to the waste pipes on the ground floor. Every time the pump is in action (when we use the washing machine), now the pump air pressure is enough to push sewage air past the u bends of my kitchen sink, smelling out the kitchen.
How can I stop this happening? Would another u-bend on the kitchen sink waste pipe help? is there a one way valve that i can install that lets waste water out but closes to air pressure the other way? Perhaps a pump that goes at a more steady action rather than in sharp bursts?
Any help appreciated. My kitchen stinks.
Toby
Welcome to the forums Toby.
Why was the outlet re routed and think I may know what`s wrong but any chance of pictures where we might spot the answer?
The outlet was rerouted as we had an extension done. I can't show the new plumbing work as it is under the floor where the drain used to be. The problem will have to be fixed 'upstream' so to speak
Meant picture of U bend and the outlet pipework from pump.
Toby
Without a picture all I can say is the most common reason for this is that the pump outlet is connected too close to the sink. All pumps activate at a certain point do not know of one that will give you your more steady action.
more than likely plumbed in before the u bend
Could be Steve however without knowing what pump is there and therefore what the discharge pressure is likely to be (15 psi or higher?) or a picture under the sink showing the connection we don`t know, did you note the part about pipe now being underground? Not many pumps like the discharge pipe to go down before a rise. Had one years back where the connection was +10" past the U bend and still could blast the plug out of the sink.
Reply to Basement pump causes sewage smell in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
