Discuss Basin tap cover - how to remove? in the USA area at PlumbersForums.net
I replaced the gland on the hot kitchen tap and successfully stopped it constantly dribbling. Problem niw is that the hot tap in the downstairs loo is dripping more. I thought I'd just do the same, but I can't get into it!
Have removed the little cap, and undone an Allen head screw inside, which is now in the handle somewhere, but can't get the cover off - any ideas?!
With the screw removed I guess it needs a little brute force to get it moving. Couple of towels to protect the ceramic and two levers to help it move.
Thanks RPM. Is it right to wangle the levers in where the red bit is?
I would say just above the red plastic ring on the cover itself. Try not to lean over the top of the tap in case it pops off and smacks you in the mouth, hopefully it will slide off once you get it moving.
The coloured part may have a screw through the top of it into the spindle and the grub screw holds the cover onto the plastic part.
As RPM above, I'd pull up above the red ring to start.
Reply to Basin tap cover - how to remove? in the USA area at PlumbersForums.net
I need to change the washer on the dripping hot tap in the photo, does anybody know how to remove the dome tap handle, there's no fixings or grub...
Hi, I was hoping someone might be able to help with this. The tap is a Bristan RS BAS C, the hot tap has been leaking and I've trying to get the...
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the...
Hi, i have a dripping hot tap on Bramham mono sink basin. I’ve replaced washer several times and can’t remove the tap head to deal with the...
Deleted member 120897
Hi guys. Very specific question... Got a RAS-C2 where the pin will only move a fraction of a mil and no amount of the usual tapping/WD40 will...
2K
