Discuss Bath Hot water inconsistent in the Central Heating Forum area at PlumbersForums.net
A
Alessandro
I live in a flat with a communal heating system and an MHS boiler in my flat. The kitchen and bathroom taps have hot water (though in the case of the kitchen tap it can take a little while to heat up but after that it will stay on. Similarly the shower also has constant hot water. The bath however has hot water but only for a few minutes then it goes cold. The hot water will then come back after 20 minutes but again only for a few minutes however its constant when the central heating is on.
Reply to Bath Hot water inconsistent in the Central Heating Forum area at PlumbersForums.net
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
I have a Combi boiler and, a few minutes ago I turned on the hot tap in the kitchen and the water was far from hot. In fact, it was decidedly...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
I recently had an eco tec plus 836 combi installed as part of an oil to gas conversion. One thing I can’t work out is why the bathroom sink hot...
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
