Discuss Bath mixer tap with shower attachment in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can I fit a standard bath mixer tap with shower attachment to my system. I have mains pressure cold supply but the hot is low pressure from a hot water cylinder. Any advice would be greatfully recieved. Thanks
no as they require equal pressures
the only way you could do it is to pump your hot supply so it matches the same pressure as your cold (best option) or run a cold supply from your cold water tank
I know they may look a bit Mickey Mouse but I fitted 2 of these Boost Water Pressure and Flow With The Quietest Of In-Line Shower Pumps - Shower Power Booster
in-line on my hot side ( gravity fed ) (mains cold) for my shower and it has worked well for the last 3 yrs , there’s an Essex flange on my cylinder so it has an Independent supply and I had to fit a low pressure shower but the pressure is pretty good and they can apparently be used on taps. There is a few second delay as the switch picks up the flow.
Reply to Bath mixer tap with shower attachment in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON...
