Discuss Bath waste leak washer required in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi All
Every now and then I have to unscrew the chrome waste which is attached under my freestanding bath and pull all the hair out from the plug hole. Unfortunately the greenish gasket/washer that goes inside the u type chrome bend which then screws onto the threaded plug hole sticking through the bath has broke in half and now the bath water is leaking slightly out of this bend when draining away. The washer/gasket is around 38mm in diameter. Does anyone know what I should order from the likes of screwfix or a plumbers merchants as it's an online click and collect at the moment. Thanks in advance.
Reply to Bath waste leak washer required in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
