Discuss Bath waste in the USA area at PlumbersForums.net
Hi all
was wondering firstly does the bath waste have to have silicone applied to washers ?
when I’ve set up in past I’ve never used it and washers alone done the job.
if silicone is recommended can I use normal bathroom silicone to do the job or would it have to be plumbers gold ?.
No not normally aslong as it has rubber washers you should be fine
Reply to Bath waste in the USA area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the...
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
