Discuss Bathroom Radiator Connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, my first official post so please bear with me ;)
I'm trying to connect new radiator in my bathroom. I want to use flexible hoses but am unsure of the connector types and sizes. Would like to order both hoses from Ebay but don't want to assume somenthing and later end up with hoses that doesn't fit...
Please could you be kind enough and tell me what type of connector/hose would I need based on the photos attached? There is one photo of my radiator inlet and two photos of the pipe that comes from underneath the flor and the valve on top of it. Obviously there are 2 pipes but the hose and connection type should be the same for both.
If it's easier to share an ebay listing rather than explaining that would be much appreciated.
Kind regards!!
Flexiable hoses arnt rated for radiator connections
Best option is to hard pipe it
ok, good to know. I wasn't aware. That changes the situation a little bit meaning I would need to spend some more time on this but that's not a problem. I still have 1m copper pipe in the garage so shouldn't be that complicated. Would you be able to tell me how do I connect the radiator end to the copper pipe? What connector?
Chrome straight rad valves
Thanks Scott. Yes, it's a long story with the mess. It was all nice and clean this morning when I decided to clean the tile adhesive around the pipes and burst one of them. Needed to cut the floor to get to the pipe, cut off the damaged bit and attach the valve slowly and properly as there's not much pipe left and I couldn't risk any mistakes.
Yes
How did you clean the existing off ?
With a hammer and small chisel. Obviously I wasn't careful enough with the first one...
Won't be making the same mistake again tomorrow
Really you only need a Stanley knife and some sand paper
Reply to Bathroom Radiator Connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Hi, I am looking for type of connector to connect my tumble dryer drainage hose (Freestanding 9kg RapiDry Tumble Dryer B5T4923R) to my sink...
I need to cap off a water connection which is the water pipe connector to an M15 hose pipe from a kitchen sprayer tap. I have included images so...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use...
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
