Discuss Bathroom Radiator Fittings - Novice! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
thomasr79
hi All,
hope you can help. Moved in to a new house and have got two bathroom pipes (the old thin style) which are exactly 575mm apart.
The radiator which is sitting here waiting to be fitted but wasn't before we moved in (Wonder why!), has the holes exactly 550mm apart.
Is it a case of getting a new radiator? After speaking to someone the other day, they said we have our pipes distanced apart in the old school way so no radiator is going to fit perfectly.
What's the answer?! Taking up the tiles/floorboards to move 25mm is not preferable!
thanks!
shut down the valves on your existing radiator, drain water out, throw away.
hang your new one on the wall, measure exactly the distance from the radiator, to your vertical pipes, take that information to your merchant and he should be able to help with a pair of new valves to suit.
good luck
shaun
hi, thanks for that. there is no radiator currently in place.
So, it just means one of the corners won't be straight in line with the fittings because it's only 2.5cm out. will just look a bit naff I guess.
no, thomas. i meant that if you put smaller valves into the radiator, you may be able to absorb the difference so the pipes will be straight!
if thats not possible the only way to do it is under the floorboards on one of the pipes.
shaun
hi All,
thanks!
you dont say whatts on the end of the pipes 575 soundslike its spaced for a 600mm ladder towel rail are the valves if fitted straigt or angled ?
gently bend the micro-bore tails with your fingers in half inch each to close the gap,
or change the rad unions for adjustables wich you can set to the right spacing. easy really.
hi all,
thanks for the comments. The pipes can bend enough to line up straight with the holes so that's sorted.
I'm sorry if being thick about this but in effect I have got this radiator
Delonghi Chrome Curved Heated Towel Rail 1400mm x 600mm
The top one. The holes are vertically under the radiator.
but the valves I have are
[DLMURL="http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9265382&fh_view_size=10&fh_location=%2f%2fcatalog01%2fen_GB&fh_search=trv4&fh_eds=%c3%9f&fh_refview=search&ts=1237840586987&isSearch=true"]Drayton TRV4 Radiator Valve & 248BQ Chrome Plated/White, 07 05 248BQ[/DLMURL]
Our pipes are coming up straight out the floor as normal.
Is it possible for anyone to link to a site which shows the correct valves? had a look around b&q for something that would be suitable and spoke to a guy there but got no help whatsoever.
thanks again
what I don't get is that the ones I seem to need is
Radiator Valves (bottom left)
So I think where Im going wrong on this is that I was expecting the thermo turning part of the valve to be vertical not horizontal which is what is needed with this part.
Sorry for that
And in fact all I need is the top left ones of this
Radiator Valves
Sorry - thanks for all your help
Reply to Bathroom Radiator Fittings - Novice! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I apologise in advance that this might not make sense or be full of silly/obvious questions, but I am a novice at all this! We have recently...
2K
A
  • Locked
First post....newbie so please excuse any errors and not using correct terminology! Conventional boiler at head height on ground floor. F&E tank...
6K
Centralheatking
C
H
  • Locked
hi guys I have a bathroom and toilet and i have a wall dividing them which i want to take down and make into one single bathroom/toilet ...
2K
PlumbBobBob
K
  • Locked
Hi all, I have an issue with fitting a towel radiator you might be able to help me with (I'm a complete novice as regards plumbing BTW). I am...
3K
robdavis
R
J
  • Locked
i would like to give as much info as i can so please bear with me about 3 years ago i took out a radiator from the bathroom so that the other half...
1K
fuzzy
F
