Discuss Bathroom sink tap valve / insert in the USA area at PlumbersForums.net
Hello
I have a dripping tap in my bathroom sink I changed all the seals and it was ok for a couple of months and it started dripping again so changed the seals again but still dripping so I’m thinking should i just replace the whole valve and if so as I don’t know the tap make can I buy any valve or does it have to be the one correct one for the tap
kind regards Antony
They are quarter turn taps
Oh dear, much harder to match if you don`t know the make but it can be done by carefully measuring the overall length of the cartridge and counting the splines on the shaft. Can`t remember who right now but somebody will be along later with the name of the company. (might be in Kent).
Used to know of a mobile or postal service company but they are sadly no longer as far as I am aware.
If you decide to buy replacement ceramic works by going to plumbing merchants or DIY sheds or S’fix to find compatible type, do take one of the tap heads with you to check it fits new works.
Ok thanks for that we a good plumb centre in town I can take it there may able to match it for me but thanks for your help
Kind regards Antony
Reply to Bathroom sink tap valve / insert in the USA area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
