Discuss baxi 105 he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andf380
been to look at a 105 he today the problem was the boiler was firing up on hot water and then reaching maximum temperature in about 30 seconds and then cutting out it worked perfectly well on the heating side i was thinking maybe the thermistor any suggestions also what should the ohms resistance be on a thermistor
thanks
on the 105e-11k ohms when cold according to m,f,i,decreasing with temp increase.HTH:cool:
it was also making some banging noises could that be due to it being sludged up
If only doing on hot water mode sounds like blocked plate heat exchanger
,requires removing and cleaning out,however if when you remove, system water in poor condition full system should be cleaned out to prevent from happening again
if i put through some x800 do you think that would unblock the plate heat exchanger
No ,if plate heat exchanger blocked up, will require removing and cleaning separately , I use spirit of salts, obviously extreme care is required
if the plate heat exchanger was blocked would that stop anything going through the condensate trap as it sempt to be dry
are you certain it was dry?is it dumping down i would be looking at a new plate heat
going back today to advise also the diverter valve was leaking and there were other slight issues would you be advising to maybe replace the boiler flush the system and fit a magna clean
Reply to baxi 105 he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
M
I've got a heating boiler which heats up the water in a tank located in a cupboard upstairs and then from there I get hot water & hearing. I get...
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
1K
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
