Discuss Baxi 105e No Hot Water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
maxumo
My boiler isnt giving out any hot water
I can see that the the little plunger that closes the microswitch isnt moving so i can assume that the diaphragm needs replacing?
The problem i have is if i close the microswitch myself which then turns the hot water light on the display and flames start but hot water still doesnt come out of the taps!
Is there anything else that might cause this?
Hopefully it is an easy cheap fix!!
This sounds as though the diverter valve is stuck in CH position.
I think it is time to get a RGI in to have a look.
Please note........ YOU MUST NEVER OVER-RIDE SAFETY DEVICES.........
David
You just need a new diaphragm kit..Part No: 5111137
You wont get hot water just by pressing the microswitch in. The diff needs to move to allow the the diverter diff to move.
Reply to Baxi 105e No Hot Water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a very strange issue with my BAXI 105e DHW. if i turn on the hot tap the pump starts and demand for DHW is shown, after a some seconds it...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Hope someone can offer some help with this issue, I have a Baxi 105e works fine no real downside, serviced looked after regularly. Have an issue...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
