Discuss Baxi 105e strange issue, for me in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I’m sure the gurus on here will have an idea what is going on with this boiler. Well boiler suddenly switches off, no ch or dhw, but main power light on no error lights etc. so check all usual suspects all fine, but, check across reset switch and output appears as about 24 volts when I/p to switch is 240v. Think oh switch take neutral from I/p and o/p short together same problem, ok take what appears to be main live when switched on off and again short that together across switch, boiler does not fire, but, 240 now across switch to pub etc. So put all lead back on switch low and behold all not works fine, dhw and ch timed and constant works for hours no problem. I fear the reset part of switch etc needs supply etc at same time as live feed to prove it. I thought I would ask my simpleton question here before I purchase a switch tomorrow. Thanks for all your help in advance
Reply to Baxi 105e strange issue, for me in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a very strange issue with my BAXI 105e DHW. if i turn on the hot tap the pump starts and demand for DHW is shown, after a some seconds it...
Hope someone can offer some help with this issue, I have a Baxi 105e works fine no real downside, serviced looked after regularly. Have an issue...
Hi I have a baxi duotec combi boiler that every day or other day needs topping up as pressure drops below 0.5bar. When fired up it can reach...
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor...
