Discuss Baxi 400/600 materials issue? in the Gas Engineers Forum area at PlumbersForums.net
Knappers
I've recently noticed some of the 'new' baxi boilers' cases going a bit yellow and am concerned that they're not UV stable and are going to start crumbling sooner or later.
Replacing a condense elbow today that has turned into what I can only describe as plasticine has only added to my concerns about baxi's materials choices.
Anyone else seeing this?
The elbows are know about and tbh your rep should of phoned you and supplied you with the new updated version eg the black one
As for case haven’t seen myself but I suspect it’s something todo with the plastic pigment they’ve used like the early white and brown soils used to turn off colour
Reply to Baxi 400/600 materials issue? in the Gas Engineers Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
PSxxxxxx
