Discuss Baxi 600.............. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There ok got some good points and bad
Medium boiler for me (the 600)
Got to quote for a mid range combi in a loft
Can't decide if I should try a 600 or stick to a logic
try the 600 mate
As it's an alu hex every year
It's going in a loft, no need for a PRV as it combined
No need for a frost stat & pipe stat as the weather comp sensor protects it
cant run the condy in solvent weld needs to be pushfit
Was thinking about this today.
The condensate adapter on the boiler is to connect onto overflow pipe. This is always solvent weld and not high temp as far as I know?
Yea don't they come with the flexibile tube ?
Reply to Baxi 600.............. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Baxi have changed their 600 and 800 ranges....they look completely different inside and out .....has anyone got an opinion on the new version.
Baxi 600 central heating is set at minimum the radiator symbol on the boiler is flashing. (asking for heat .fan is still running ) this is like...
Baxi DUO-TEC boiler Trying to repressurise using the 2 blue valves - left valve won't budge. Any ideas please?
Hi. I’m new here and due to have a new boiler fitted. Does anyone have recommendations or thoughts on either the Worcester 8000 40KW Combi or the...
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted...
