Discuss Baxi BBU with Bermuda fire front. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Baxi BBU AND Bermuda fire front. Both are in perfect working order and we’re not looking to have a combi installed anytime soon.
Are there any fire fronts that are compatible, if we wanted to change it?
Fire works perfectly. But it’s ugly!
I have seen an SP3 on Ebay, but not sure whether it would be compatible or not.
You could contact Baxi for a list of compatible fronts but I would think you will struggle to find an installer to fit a fire front that you bought yourself from ebay. I would find the installer first before you buy anything.
Give Baxi a call and they will guide you to compatible fire fronts, although only from their own range I would assume.
As above, contact your RGI first either way as they may be unwilling to fit parts not intended to be used with the Baxi BBU.
One of the reasons being, the flue performance may be affected and carbon monoxide as we all know.......is a killer.
Reply to Baxi BBU with Bermuda fire front. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
