Discuss Baxi combi pressure issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Looking at a baxi combi tonight. Pressure drops to 0.2 but will go up quite high when running on CH. Needs repressurising regularly.
I don't have a lot of info yet but what could cause this?
I'm going to check prv and ex vessel anything else I should look at?
Thanks Harvest Fields.
Pressed schraeder valve, no water but no air either. Couldnt recharge because my pump was broken.
Would this cause the same symptoms?
Recharged last night, ran it on max until it went up, usual rise on gauge from 1bar. Not heard back, fingers crossed.
I use to say that now can' be bothered just tell them get new one.
Must admit to getting a bit the same, because you take the time to repressurise it and it fails to cure it 2/3days later ,then they never expect to pay for one of the visits
Reply to Baxi combi pressure issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
PSxxxxxx
