Discuss baxi duo tec pop fuses on the pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
julesverne
just gotta a call and on my way to go look at this duo tec he that periodically pops fuses on the board. any thing i should be looking at with the multimeter. is there a common problem?
thanks in advance for amy help
Surprised it's a HE A, they're usually much better and don't leak. The HE isn't common, but I've changed a few, one on Monday. I changed the lot rather than changing the top, which was a bit of a pain, but it had been leaking that bad the chassis had turned in to a brown mess.
Reply to baxi duo tec pop fuses on the pcb in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I wanted to ask is there a function to remove air from a Baxi duo tec combi 24 HE A. If there is can some one kindly tell me the...
Baxi Duo Tec 28 Hot Water Issue. Hi, I have a Nazi duo tec 28. I’m having an issue with my hot water. If the CH is on, and I turn on the hot...
Deleted member 120897
    • Funny
    • Optimistic
Hi, I've got a ferroli 901 boiler, I initially thought the pcb was at fault so bought a new one and I'm having the same problem ( has been...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Hope someone can offer some help with this issue, I have a Baxi 105e works fine no real downside, serviced looked after regularly. Have an issue...
