Discuss baxi duo-tec2 fault code e385 in the USA area at PlumbersForums.net
as above driving me insane about ten people from 27/4 rescue looked at it can not find problem,i get hot and ch but it takes a while for it to come through all the time flashing 385 then all of a suden will fire up and be fine
Low incoming voltage eg below 200v ac best have a word with a sparkie I would say
Hi, did you get this resolved? I’ve had the same issue occur. Was it a pcb fault or some other electrical issue?
thanks
Reply to baxi duo-tec2 fault code e385 in the USA area at PlumbersForums.net
Baxi Duo Tec 28 Hot Water Issue. Hi, I have a Nazi duo tec 28. I’m having an issue with my hot water. If the CH is on, and I turn on the hot...
Deleted member 120897
Hi, I am handy DIYer but not interested in touching anything boiler related! Just interested before I get a Gas safe engineer out what I could be...
2K
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
Hi all I’m having a problem with my Baxi combi boiler and wondering if anyone is able to help. In short, the water isn't heating. A few months...
1K
