Discuss baxi eco80 melting venturi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dazza3674
hi all hope you can help
boiler stopped working othe day, thought inital fault was aps so fitted new one.didnt fire up still, found prob to be melted venturi. replaced venturi and fan all working ok...24 hours later boiler failed again another melted venturi. this combi boiler does not have a room state fitted so its relying on boiler sensor to cut out when reaches temp. im going to install a room state when i return from working away. my question is what could make boiler produce so much heat that its melted 2 venturies..is there a temp sensor on pipe that could be faulty or poss pcb fault..flue is clean. radiators getting to hot to touch which leads me to think a sensor or thermistor is faulty.
thanks in advance
darren
Hi Darren I would urge you to get a gas safe registered engineer in to solve this problem ASAP.
Reply to baxi eco80 melting venturi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It was fitted with the boiler a Potterton Suprima 30L about 21 years ago. Two PCB's later and a new fan the boiler is working perfectly. However...
1K
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
I
Dear All, Please kindly advise, i don't know what else to do! Had new boiler Vaillant 424 heat only open vent boiler installed with new flue and...
5K
Deleted member 120897
