Discuss Best chemical sink unblocker? in the Plumbing Tools area at PlumbersForums.net
gmartine
Which make is fairly foolproof? I tend to almost always go down the mechanical unblocking route but I want to leave a few bottles for a few tenants (not mine).
The stuff you get in the shops is pretty dilute, and hence fairly safe. Buy them a pair of cheap goggles while you're at it. Anything with sodium hydroxide in the ingredients is good. Sodium hypochlorite is a bonus. I'm a rare oddity in being both a plumber and a chemistry graduate!
Plungers cause all kind of problems, as the compression they generate can wreak havoc on pushfit and compression connections, such as the ones that connect the trap to the pipework. There's always a better solution.
If you want to give them a decent means of mechanically unblocking waste pipework, buy them a TITAN wetvac from Screwfix for around Ā£50. The vacuum in the pipework is unlikely to cause leaks. They'll need to cover the overflow of any sink or basin in order for it to be effective if they're sucking out from the waste AKA plughole
Benedict
Pedal Powered Plumbing
I asked a drain engineer what he does when he gets a shower tray block or sink thats hard to get to waste and he said boiling water with a strong bleech and leave in trap , it does seem to do the trick .
Reply to Best chemical sink unblocker? in the Plumbing Tools area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
