Discuss Best solution for a failed expansion vessel? in the Central Heating Forum area at PlumbersForums.net
I have a Vaillant Turbomax Plus boiler, fitted in 2005. Recently it's locked out several times due to low pressure, which prompted me to check the expansion vessel. When I pressed the Schrader valve I found that water, rather than air, was released. That suggests to me a failure of the diaphragm? I read somewhere that it's often easier to have an external expansion vessel installed than to replace the original - does that make sense to the experts?
External expansion vessel certainly, way cheaper to buy simple to install. Make sure you get the right capacity vessel. Look up BES on line to see how cheap they are. Centralheatking
Reply to Best solution for a failed expansion vessel? in the Central Heating Forum area at PlumbersForums.net
